Tire combos
Tire combos
What is everyone running for tire combos on there cars? Size and brand? I’m looking at the Goodrich radial GT white letter tires at the moment but not sure how it would look on my car. Can Anyone post some pics of different cars and tires for me. Thanks!
Matt
Matt
Re: Tire combos
Bueler? Buelerrr?
Re: Tire combos
I'm running Cooper Cobras all round. 215/65/15 front and 235/60/15 rear with 15x7x3.75BS Torq Thrust IIs front and rear. If doing it over, I probably would have gone 205/65 or even 205/60 on the front. The 215's are a bit tight. Problem is Cobras don't come in either of those sizes. I mounted blackwalls out just because I prefer that look.
Re: Tire combos
Those look good, how much lower is your car from stock? My wheels are 15s 3.5” bs. I think im good on the front cuz my tires are 205/60 15s but the back I’m running 215 70 15s and they are way to tall and rub on the front of the wheel well. Not sure why the rear ends in these cars seem so far forward like they aren’t centered in the wheel well.
Re: Tire combos
I don't know how mine compares to stock, but it's sky high compared to Sassy. I'm at 11 1/2" at the front and 14" at the rear on the rockers. Part of that is replacement rear springs that have yet to settle down, but I expect it will settle in the 11 - 11 1/2" range.
Re: Tire combos
Jim, my car was up even higher then that when I started this project! My dad had originally installed these leaf spring hangers cuz he wanted the rear end jacked up. I think when I initially measured it it was up almost 18”! Looked like a monster truck lol.
https://postimg.cc/gallery/Kg9kbDW
Re: Tire combos
I'm running 225/60/15 on the front; 295/50/15 on the rear. Pretty sure these wouldn't fit on your car without some modifications.
Re: Tire combos
205/60R-15 all the way around on 4.25" backspace 15"X7" Mag 500s. Diameter is same as stock 13 that came on the car. Tread width is maxed out.
Finding many manufacturers have dropped this size from their line. Still available in BFG Radial T/A.
A lowered front stance would help a bit on the 3>4 bang shift, keep the car from floating but that's part of the fun
Re: Tire combos
Jim, I didn’t think 295s would fit on these cars, nice work! Did you go to a 4 link or something?
Joe, wish I could bang shift my car, it’s an auto Some day I’ll get someone to help me install a 427 and a top loader! In the meantime I got the Camaro to bang shift but somehow it’s just not as cool!
Re: Tire combos
Re: Tire combos
Twins from another mother
- 0532047D-0BFE-444E-B3AD-334400A66026.jpeg (133.08 KiB) Viewed 1596 times
Re: Tire combos
My car has been altered too much to be any reference to you in tire sizes. At the moment it is up on jack stands so cant even give you a rocker height.
Re: Tire combos
Heck, install high-stall converter and slapstick shifter w/ reverse manual valve body
Was really into the 'big & skinny' look years ago. Thought about going back to it but the wide front meat, front crossmember, MII power R&P & some negative camber makes this a really fun car around the curves. Don't bang shift on enough straights to justify changing a thing, really. Maybe a Monte Carlo bar.
