65 Rear trim fasteners
Does anyone have a picture or a source for the fasteners that secure the 3 aluminum trim pieces between the tail lights? I assume it is some type of T-head bolt?
Randy
1965 Mercury Comet Caliente Convertible
Re: 65 Rear trim fasteners
I don't know about availability but mine are fresh out of the ultrasonic. If I can find them today I will post them up. DM
Not sure if you are looking for original, but if you don't care if they are original or not these would work. You can trim the wire to fit or even take the wire off if need be. I use these universal fasteners a lot . They come in many sizes, are cheap and are easy to modify, ( grind to fit etc.) I am thinking this is the right size for the rear panels. But I can check tomorrow when I go to my shop.
https://www.amazon.com/25-Universal-Mou ... C94&sr=8-5
If you're talking about the trim pieces across the back of a Cali or Cyclone, this is it.
Thanks Jim. I saw that in the manual but couldn’t find a part number or description. I think I found one actually stuck in a spare trim panel. I was looking for something bigger. The stud is a 10/32. Nevertheless I only found one. The one I found is very similar to this..which I think I have.Jims65cyclone wrote: ↑Sun Feb 27, 2022 8:42 pmIf you're talking about the trim pieces across the back of a Cali or Cyclone, this is it.
https://www.falconparts.com/?atc=1&idproduct=6916
That circular object on the threads is a neoprene washer
Randy
Thank you Lou. Good option.Lou's Comet wrote: ↑Sun Feb 27, 2022 9:40 amNot sure if you are looking for original, but if you don't care if they are original or not these would work. You can trim the wire to fit or even take the wire off if need be. I use these universal fasteners a lot . They come in many sizes, are cheap and are easy to modify, ( grind to fit etc.) I am thinking this is the right size for the rear panels. But I can check tomorrow when I go to my shop.
Randy
You might try some of the links in this post, compliments of kevinshi:
viewtopic.php?f=23&t=15429
