Need help phantom drain
Comatt
Post by Comatt »
Hey guys, still trying to chase down a phantom drain in my 65. New alternator, new battery, new regulator. Car reads 12.8 volts on the battery, when I turn it on it on and turn on anything in the car I get 12.4. Battery keeps dying as it’s not charging. If anyone could give me any ideas where to start to fix this problem let me know. Thanks!
Matt
Re: Need help phantom drain
What’s your battery read in volts with the car running? I believe your alternator should put it around 14.2 - 14.7 volts if working properly.
Though new, the alternative may be bad.
Comatt
Post by Comatt »
With the car running battery reads around 12.4 volts. Been dealing with this problem for a few months. Previous alternator tested good but I just put a new one on to see if I still had the problem and it’s still not charging.
Where to start.......belt tension on alternator?
You definitely have a charging system problem. If the belts are tight and alt is good, it’s more then likely something to do with the wiring. Start checking continuity, breaks in wires, fuses, and grounds.
JimsHot66
Post by JimsHot66 »
Caveman49 wrote:
Thu Jun 30, 2022 1:41 pm
Ditto on the above, as well as possibility new alternator could be bad.
Just wondering, do you have an external voltage regulator on your car? If so, that could be the culprit.
Comatt
Post by Comatt »
I do have a voltage regulator, replaced it twice already. Don’t think that’s the problem.
I had this problem a couple years ago on a Jeep.
Mine was corroded alternator ground. Cleaned it up w/ steel wool, viola fixed.
Comatt
Post by Comatt »
Will check out the grounds and wiring and post again if the problem is fixed or not!
