Wiper switch
Comatt
Wiper switch
Post by Comatt »
Anyone know where I can find a new wiper switch for a 65? I have the dual switch with the button in the center for the windshield washer. Thanks guys!
Re: Wiper switch
Look thru this thread before you waste money on a stock switch that wont work like it should.
viewtopic.php?f=10&t=16890&hilit=interm ... per+switch
they were a bad design that failed . & motor is only one speed with delay. if your switch still works for one speed that's as about asgood as it will get with stock parts.
Comatt
Re: Wiper switch
Post by Comatt »
Unfortunately switch is completely dead. No speeds at all lol
Re: Wiper switch
Check wiring back of switch and at the motor
JimsHot66
Re: Wiper switch
Post by JimsHot66 »
Fri Nov 04, 2022 4:20 pm
On my 66 there was a circuit breaker (small rectangular metal box) on the switch. Might want to check for that.
Re: Wiper switch
Did you figure out if you needed a switch for sure? I was going thru my stuff,getting ready put the 80's truck switch on ,& found my old switch. I was told there are 2 different ones both similar have a different hole in the back of the little knob. Mine has the square hole ;
with a square stem ;
If this is like yours I could sell you my old switch probably a lot cheaper than the NOS ones that come up on ebay ever now & then. I didnt think about it back when you mentioned this,,,,, but I wont need it so I could let it go but I may use my knob so I want to keep it.
