Lazy post here, None of the interior lights in my 65 4 door work. neither cab or the roof interior light. the only one that works is the High beam red indicator!
Is this likely just a single fuse or could it be more complex?
Interior lights not working
Re: Interior lights not working
Check the 2.5A in-line fuse from fuse box to instrument panel.
Wire should be blue/red stripe.
Thank you Joe, I will report back once I get a chance to get into the car!
1965 404
Well I could not find an inline fuse just looking around from underneath but my dome light fuse and the shorter one beside it both have corroded terminals so I will try and clean them up more another day. Likely that is the problem.
1965 404
