Hi all,
Does this look correct?
The rod end of the pitman arm goes on top of the center link if manual steering and using the correct center link for a 65 comet/falcon?
Because if I compare it to a 67 mustang I have here, the pitman goes underneath on that one.
pitman on top?
Re: pitman on top?
Ok never mind
I found it in another post (below) and is correct........whew!
https://www.cometcentral.com/forum/view ... hp?t=15083
cheers!
cheers!
Re: pitman on top?
It can only go together one way, the sector shaft and the tie rod hole are tapered.
Re: pitman on top?
It will seat in the taper just like a tie rod. A little anti seize will help it come apart easier in the future.
