pitman on top?
iglooman
pitman on top?
Post by iglooman »
Hi all,
Does this look correct?
The rod end of the pitman arm goes on top of the center link if manual steering and using the correct center link for a 65 comet/falcon?
Because if I compare it to a 67 mustang I have here, the pitman goes underneath on that one.
iglooman
Re: pitman on top?
Post by iglooman »
Ok never mind :)
I found it in another post (below) and is correct........whew!
https://www.cometcentral.com/forum/view ... hp?t=15083
cheers!
Re: pitman on top?
It can only go together one way, the sector shaft and the tie rod hole are tapered.
iglooman
Re: pitman on top?
Post by iglooman »
Wed Jun 21, 2023 2:59 pm
Very true. I see that now.
As far as the ball joint in the idler arm.........I assume I have to tighten the castle nut until the center link is tight against that?
Re: pitman on top?
iglooman wrote:
Wed Jun 21, 2023 4:32 pm
It will seat in the taper just like a tie rod. A little anti seize will help it come apart easier in the future.
