Hey guys does anyone have any pictures of the voltage regulator wiring on your car? One of the wires popped off on my car and they all seem to be yellow so not sure what position it goes to. My car has two yellowish wires on the A and S terminals. The wire that popped off would need to plug into the I or F terminal and one of those I assume doesn’t do anything? Thanks for the info.
Matt
Voltage regulator wiring
Re: Voltage regulator wiring
Thanks johno the diagram helps. It seems the I terminal isn’t used. What would that even be used for? Just curious
- FuzzyDriver
I believe the I terminal is for the dash "Charge" light. I for indicator. Our Comets don't have one; we have an ammeter instead (Falcons have the light, but no ammeter).
OK...so she might need a little work.
