4 ways switch installation
Brent F.
Post by Brent F. »
I'm looking to see if anyone can give me any information on installing a new emergency flasher switch. The previous owner had removed the switch and did some rewiring to make things work. Sadly the gage lights do not work now. I have purchased a new headlight switch and the flasher switch from Melvins Ford Parts but I am not sure of the correct way to wire them in. Anyone with any incite on this problem will be well appreciated. Thank You
Re: 4 ways switch installation
Can't answer you question, but welcome aboard! :D What year is your Comet? Mine's a 65 and was not equipped with emergency flashers.
Brent F.
Post by Brent F. »
Mines a 65 Caliente Convertible
Welcome on! comethead tried to add the emergency lights to his a few years ago but I think he gave up on the idea. I always wondered if it was because of the way the comet front signal/parking lights were wired from the factory> parking lights go off when headlights are on unlike newer cars that leave them on for running lights. But there is a way to convert that by making some changes at the light switch.
btw Nice car !
here is a wiring diagram if you need it.
Brent F.
Post by Brent F. »
Thanks for the diagram. My son is an electrical engineer and should have no trouble figuring out what needs done. I wonder if any of the 65's came with emergency flashers. And yeah your cyclone is pretty bad too
Brent F. wrote:
Wed Feb 12, 2025 3:34 pm
Thanks but mine is a caliente. yes 4 ways were an option for all comet models,here's the options for all models in 65.
Brent F.
Post by Brent F. »
Sorry poboyjo I thought you were Jimcyclone. Thanks for the info. If it came as an option, theres gotta be a way to make it work. Wish me luck.
So I was curious about this & was looking at how the mustangs did it. for the first ones up until late 66 had an add on harness for the emergency flashers. so you would just unplug the multi wire connector at the steering column & insert the harness to tap into the front & rear lights & it has one power wire to the cig lighter attaches same way ,then some wires to the switch .
this would be the way I would try to add them on without splicing into my original wiring, it would be plug & play I believe,according some of the vendors which say their harness fits comets,falcons, & mustangs. but even if something is different your elec tech son should be able to change the add on harness easier than changing you cars wiring harness. But! since someone has changed your wiring it may not be plug & play! lol but here is one of the add- on harness I mentioned, I did see some cheaper but I'm putting this one up because it says it will work on a 65 comet;
https://www.macsautoparts.com/1965-3-1- ... 196-1.html
& here is harness only;
https://www.kentuckymustang.com/wiring- ... C8QAvD_BwE
Brent F.
Post by Brent F. »
That's the exact same switch that I got from Melvin's Ford parts so I guess I'm on the right track. Just hope the previous owners wiring job hasn't screwed up too much. I see they put a 10 amp fuse inline on one of the wires. Don't know what they were thinking. Once again, thank you for the information and once both me and my son have the time, I will get back to you to let you know how things went. Thanks again
FuzzyDriver
Post by FuzzyDriver »
I see no one has mentioned Ron Francis. It is a big operation, as far as I can tell. Not cheap, but they go on and on about guaranteeing success, tons of support, and have had lots of positive reviews. Here's a link: https://www.ronfrancis.com/
OK...so she might need a little work.Image
