Hey guys, this is my first post on your web site. I am in the market to buy a comet and have always liked the cyclone. If I cant find one is there a way to change a regular comet into a fake cyclone ? Where can I get the parts ?
Thanks
Hey, new to web site, 64-65 comets / cyclones ?
- CometInTheSky
Welcome C.i.t.S. to the forum and Comet Central
Sure you can build a Cyclone out of regular Comet (as long as it's a 2dr hardtop) there is nothing special about the Cyclone it mostly is a trim level and engine change, trim would be the easy part because there is a lack of trim on the Cyclones. You would need to look for a Caliente to start with and remove all the trim and weld the holes up. Calientes came with all differant engines from the sixes to the big V8s you would just have to decide on what you wanted to build and just start collecting parts.
Check out the links section in the forum and on the website for some sources of parts.
Some others here will probably have some suggestions also on what you would need to do that are far more knowlegable than me.
- Comet Central Member
