Lou's 65 Comet Build
Re: Lou's 65 Comet Build
Mon Jan 06, 2025 10:45 am
Hey, Lou! Are you going to weld clips to the housing to snug up the rear line?
Just wondering if it's necessary, also considering factory practice.
Thanks for all of the cool pics!
Really like the proportioning valve location. Gave me an idea :idea:
Not going to weld clips to housing. Might glue a couple, or going to use straps like Moser sells. I am going to do something to snug them up!
tomb22 wrote:
Tue Jan 07, 2025 12:25 pm
You do awesome work Lou. I have totally enjoyed watching your project and thanks for the detailed pictures. I know what it feels like to build a one of a kind to your liking. Glad your having fun with it.
Tom
Thanks Tom, I am definitely having fun.
Lou's Comet wrote:
Wed Jan 08, 2025 8:17 am
Have some snugging up to do myself, Lou.
Went back and reviewed your early postings on the build. Your car has come a long way since you picked it up.
A lot of great ideas and great pics still hanging in there. A lot of details!
Thanks man
Deiv_67
Post by Deiv_67 »
wow! its very beautiful!! :shock:
Full restoration '67 from Spain: viewtopic.php?f=10&t=17884
warren1328
Post by warren1328 »
Loving your work Lou!
Especially the brake lines.
I'm collecting parts to swap to dual master at present, but scared of bening/flaring etc...
warren1328 wrote:
Sat Jan 11, 2025 6:11 pm
Buy extra line, it's cheap and practice makes perfect.
It might be worth your time to use NiCopp brake tubing. It bends and flares very easily. I use it exclusively for brake and fuel lines. It is DOT approved. It is available in rolls which is easily straightened for long runs. I purchase mine from Summit. Invest in a quality flaring tool, it will make the job much easier, I also lube the tubing with white grease when making a flare, then clean the tubing inside and out with Brake Klean before installing.
warren1328
Great suggestions, thanks guys.
Will be saving making new lines etc until I pull the car apart for proper resto.
Will be much easier job when it's on a rotisserie and I'm crawling around on a concrete floor :D
Thanks Warren,
Brake lines aren't that hard to do. Make sure you cut the line square and prep the end before you flare. This tool here preps the end of line.
Shttps://www.eastwood.com/eastwood-tubing-deburr ... OlN3pyPdho
I use to prep the line ends with files, round and flat. This tool makes it much easier and prepping the line makes a much better flare!
A really nice flare tool is
https://www.eastwood.com/professional-b ... -tool.html
A little pricey but works every time . If you're doing Nicopp the cheaper flare tool will work.
No matter what you use prep the end of the line correctly for a nice flare.
Worked on my exhaust this week. When back and forth on what mufflers and finally decided on the Black Widow mufflers. I also bought these tailpipes from summit to have something to start with.
https://www.summitracing.com/parts/flo- ... /year/1966
Had to cut a little out of the pipes and re-weld them.
Here is a picture of the tailpipes done. The front pipes are just straight pipes with a 12 degree bend 6" from end for left side. And 9 degree bend for the right side to line up with the headers. And the mufflers.
The mufflers are pretty much straight thru.
Here is what it will basically look like assembled.
I still need turn down tips. The exhaust tucks up pretty good and the tips will exit behind bumper with just a little of the turn down showing .
Made my own hangers by bending the universal type hanger and welding to clamp. Didn't want to weld to pipe in case I wanted to change anything or made any mistake. This way I only need new clamp instead of pipe. Also made some plates with studs that go in from other side to bolt hangers to and some rubber gaskets to seal the holes.
Here is how hangers look on car
Test fitted everything a few times and pretty happy how it all fits. Need to paint hangers and brackets, get the turndowns and then install. Looking forward to hearing how it sounds.
Tidy tidy, very clean!
You won't be sneaking around with those mufflers!
Lou's Comet wrote:
Sun Jan 26, 2025 8:56 am
So are we!! :D 8)
JimsHot66
Post by JimsHot66 »
Car is looking GREAT Lou. I bet your neighbors will love it when you fire it up with those mufflers. :shock:
Sun Jan 26, 2025 10:17 am
Thanks Fred
Sun Jan 26, 2025 3:49 pm
So are we!! :D 8)
Getting close :)
JimsHot66 wrote:
Tue Jan 28, 2025 2:46 pm
Guy across street from me has 69 Z28 with pretty loud exhaust. Also a bunch of car people on my street.
64 Polara wedge
65 Nova SS
66 Chevelle SS
69 Charger
67 GTO
I will fit right in.
Well the name plates you've listed will all be envious that's for sure!
