Thanks Vicegrip,,,,,,I do have a AFX type fiberglass hood, and was leaning toward a performer rpm intake. Hopefully it fits. But yes under hood clearance will be something I keep in mind as I pick intake, carb, air cleaner.
Yea it is. I am also old school, last engine I did (other than just a stock rebuild) was like 35 years ago.Joe Travers wrote: ↑Thu Feb 17, 2022 10:51 amPretty cool how engine technology has advanced since these cars were new. Streetable 302 now makes more power than Shelby's wild racing 289. Small-block stroker makes more power than FE 427 hi-riser. I'm old school, before aftermarket but did buy a few things from Ford Motorsport for my son when Fox bodies were his thing.
Lou, I'm running a Holley on Performer RPM w/ a 1" open spacer to get cross flow in the plenum. Also running 14" X 3" air filter w/ flat base and it all fits under the stock hood. Keep on keeping onLou's Comet wrote: ↑Fri Feb 18, 2022 7:22 amI do have a AFX type fiberglass hood, and was leaning toward a performer rpm intake. Hopefully it fits.
Yes I did purchase the heads already. The heads are getting hard to get and didn't want to wait 9 months to a year.Joe Travers wrote: ↑Mon Feb 21, 2022 10:44 amHey Lou! Have you already purchased the 185 heads? Just throwing this out there......
The 185 is the max head for 4.00 bore. Being you are running large bore, you could step it up for mo' power
I don't spend other guys' $$ but it's a real thing.
On the exhaust side, the Renegade 185 is still a pain in the butt. I temporarily sorted out plug wire boot problem w/my Hookers using a MSD button boot on #3 plug. The only ones I could find were 8mm. I'm running Autolite plugs. Accel shorties may help in that regard if you can find the correct heat range. I have my 3rd set of wires in the back floorboard, trying to get it just right. Would be best to check it all while you still have the engine on the cherry picker, in case you run into this.Lou's Comet wrote: ↑Sun Feb 27, 2022 9:26 amBut I did think about going bigger on the heads but the larger AFR heads have raised exhaust ports and that would likely create some issues with exhaust. Also they were not available. Talking to my builder he said the 185's would work fine!
Thanks Jim, got to admit I am getting anxious, and maybe a little bit excited, lol
Thanks Joe.Joe Travers wrote: ↑Sun Mar 06, 2022 9:37 pmLooking great, Lou!
I was chasing down a black on black '65 Cyclone couple years ago w/ Cragers.
Kinda gettin' jelly
Thanks,,,I actually made the dash/bezel myself. And I did have to modify the factory dash.rmertz3282 wrote: ↑Mon Mar 07, 2022 7:36 amLou your dash looks great. Where did you source the bezel? Does that mount in the original location without modification?
