header wrap
header wrap
OK so I purchased a set of Doug's headers, painted them with 2000 degree rust proof paint and let it dry for 3 days, wrapped the headers with DEI wrap ( butt ugly stuff, looks horrid to say the least). Am I going about this the right way ? Any pros , con's on this. HELP
Re: header wrap
I have no experiance with the wrap but have heard from many sources that it holds moisture and will cause rust! ROY.
Real Racecars have 3 pedals
Re: header wrap
MY Hedmans specifically said to not use wrap as is will greatly shorten the life of the headers!!! and void the warranty I believe
Re: header wrap
Thanks for your help. Gotta be the ugliest I've seen. Taking it off and buying a starter wrap instead glad I didn't put the sealant on yet
Re: header wrap
I bought a car with header wrap already since the headers were too close to the starter and affected the performance of the starter...and was pretty ugly........so after I got my headers ceramic coated, I didn't use the wrap and got a heat shield that goes on one side of the starter which reflects the heat away....much better.
Re: header wrap
Took header wrap off. Started putting Doug's headers on yesterday. Wow 7hrs later one side on and its so tight to the frame rail that the motor would not slide back into its mount. So much for the idea of from box to block. Gonna finish that side today or at least try. Getting very discouraged but can't send them back way to late and I had to use my bfh a lot .
Re: header wrap
I must have been lucky with my Dougs Tri-Ys,they went on on both sides not even touching anything,frame,body or engine,did not even have to loosen the engine mounts!!!The car is my 65 Comet wagon,302 four speed,stock clutch linkage!! ROY.
Re: header wrap
you might check and see if they sent you the right headers, I got mine from summit and spent a few hours putting them in had to pull the trans and bellhousing and then they hit everything including the pitman arm only to realize that they sent me headers for a mustang and they WILL NOT FIT!!!! summit sent me the right ones for a comet and they went right in the car, they are close in a couple spots but do not hit anywhere.
Ant
Ant
Re: header wrap
To late a few dents here and there but I'm going to make them work. Would of helped if I would of shaved the shock tower. Going to add a little heat to the one on the drivers side and bend away from frame rail. Moving forward slowly but at least moving lol
Re: header wrap
WOW,sorry to hear you are having so much trouble,I know every chassis is a bit different,but no heat or hammers were necessary in my installation,BUMMER!!!! ROY.
Re: header wrap
Oh well live and learn. Won't do this again. I'll pay someone else. Do I regret this no I love a challenge . car sounds real good tho.
Re: header wrap
Tri-Ys are a great street addition,should work out for you!!! Figure ol Shelby got over 300 HP back in 1965 using Tri-Ys on a 289!!! ROY.
Re: header wrap
I never realized how much room there wasn't under the hood till this experience. That will change in the future. My next step is to connect the frame rails really looking forward to that. Couldn't put my new springs in the front because previous owner welded in the perch mounts on both sides so next year new upper a-frames. I'm slowly getting the car ready for more HP about 8,000 new motor and trany . I have high hopes for my old girl. Will I ever finish this no there will always be room for more improvement some where. Gonna post more stuff for sale soon got to clean out the garage I'm running out of room to put things lol
Re: header wrap
Hey Hot
Dont plan on finishing it, get it runnin and keep improving!
That has been my plan for 40 years, just didn't know it
