Page 10 of 13
Re: My first 1964 Caliente/Comet project
Posted: Tue Jun 15, 2021 4:38 am
by Red Lehr
Joe you are welcome to stop by anytime!
Posted: Fri Jun 25, 2021 5:30 am
by Red Lehr
The firewall seems to fit pretty well...I wanted to do some bead roll design on the firewall and in my rookie haste I forgot to do the bead rolling first
I lowered the engine 3/4 of an inch and I have a 6 1/2" drop from the trans tail shaft to the center of the differential...I'm not sure how to deal with that problem yet.. Any suggestions ???
Red
- 20210625_040631.jpg (241.36 KiB) Viewed 2978 times
Posted: Fri Jun 25, 2021 11:10 am
by Joe Travers
Red Lehr wrote: ↑Tue Jun 15, 2021 4:38 am
Thanks man! I'm way down here in the land of cotton but you never know
Crites sells the correct motor and tranny mounts for your application here-
https://www.critesperformanceparts.com/page7
May get some ideas from Loman's FE install here-
viewtopic.php?f=9&t=15203&hilit=loman
Posted: Tue Jul 27, 2021 8:13 pm
by Red Lehr
Posted: Tue Jul 27, 2021 11:39 pm
by SASSY
Cool Red!
Enjoy your fab posts, not only what your doing but all the work that can be seen in the background. Its like rereading previous chapters of a book.
Posted: Sun Dec 12, 2021 3:01 pm
by Red Lehr
- IMG_20211210_033000.jpg (162.98 KiB) Viewed 2832 times
by
- 20211123_153454.jpg (136.99 KiB) Viewed 2832 times
Posted: Thu Dec 23, 2021 9:20 am
by Teddyzee
The quarter openings look great. I scrolled back to see that you made them, that''s a terrific looking project!
Posted: Mon Dec 27, 2021 4:19 am
by Red Lehr
- IMG_20211227_031053.jpg (172.79 KiB) Viewed 2774 times
One side all welded in.
Posted: Mon Dec 27, 2021 9:21 am
by SASSY
BEAUTY !!
Posted: Tue Dec 28, 2021 7:16 pm
by tomb22
You do nice work
Tom
Posted: Fri Jul 22, 2022 4:22 am
by Red Lehr
Posted: Fri Jul 22, 2022 10:42 am
by SASSY
Looking great!
Thinking about attaching the tub to the 1/4, Im thinking the adhesive.
The chassis may not flex but the body might some, if it does it will stress the tacks which may show through on the body finish and or crack near the welds. I would think a bead of adhesive under and over tubs would have clean look and spread out any load caused by flex.
Wish I'd a had the talent you have and back halfed my car similar to yours,,,
Posted: Fri Jul 22, 2022 4:48 pm
I'm with Fred, I love the 08115 3M body adhesive. Saves a lot of work. no worry about welds rusting in places you cant get to to sand/grind & seal. you are gluing & sealing all at once, eliminating some steps needed when welding. & can be sanded & painted.
Quarters look great! progress is all looking good!!!
Posted: Mon Jul 25, 2022 9:29 am
by Red Lehr
Thanks for the kind words and help fellas !
I never fabbed sheet metal until I started this project and it just takes practice and time and a few good tools.
Posted: Mon Jul 25, 2022 1:22 pm
Red Lehr wrote: ↑Mon Jul 25, 2022 9:29 am
well you cant tell it by looking, it looks great! Hard to see where you did anything !
Look like an old pro did it!!!
Louscomet gave me some tips on gluing my cowl cover on with the adhesive in case you decide to use the adhesive . I think you'll like it & use it on other parts of your build. I used it on parts of my minitubs,trunk gutters,parts of the floors,& soon the top of the cowl .
Here are the tips Lou gave me;
Just a thought but if it was me I would get a second tube of 8115 just in case, ya know.
If you don't open it you can always send it back.
You need to put a coating on the bonding area, (perimeter) of both surfaces, then run a bead on one of them (I would do this to the surface on car.) one tube might do it, might not. Plus the adhesive you will need to replace or cover the hats. But you don't want to run out in the middle of the job.
I use tin brushes to spread the initial coating on the two bonding surfaces. They are cheap, work great and ya toss them when done. Then run like a 3/16 bead in the middle of the bonding strip so it squeezes out both sides. If you want to be sure run a little bigger bead, but you want it to squeeze out both sides. You can do a test when you first open the tube. Ya need to run a inch or two out first to make sure it is mixed. You can use that inch or two to test with some scrap to see if it is squeezing out both sides.
But you do not want to run out of glue !
Also after prepping the car, and inside of panel, I grind the bonding edge with 24-36 grit on a angle grinder (rough it up good) Then cover that edge with 3/4" masking tape. Then you can coat the car side with POR or whatever you decide to use. And I would also do the inside of the new panel. Prep the edge, tape it and paint the inside of the panel. The paint that comes on panels in my experience doesn't hold up well. I use a spay can of VHT epoxy to do the inside of panels.
