My first 1964 Caliente/Comet project
Re: My first 1964 Caliente/Comet project
Finally got around to getting the frame cut and now the the frame is at the original factory ride height.
I also got started on the rear quarter metal work.
1964 Comet Caliente/1964 Galaxie 500
I wanted to share a quick update.. I had to replace the tail panel that sits behind the bumper with new sheet metal. Getting the frame tied in with the rear sheet metal.
- Attachments
- 20200719_161655.jpg (184.61 KiB) Viewed 271 times
- 20200721_130947.jpg (173.36 KiB) Viewed 271 times
- 20200804_144430.jpg (204 KiB) Viewed 271 times
Dang, Red. You are a welding fool! Keep it up and keep posting.
I did a little mocking up over the weekend. It looks like the engine will fit under the "teardrop" hood.
The engine is still setting higher than expected which leads me to a new problem. The crankshaft is currently 6 1/2 inches higher than the rear differential....Are we having fun yet ??? LOL
Did you fabricate those rear quarter panels yourself?? they look awesome! I need a pair of those made bad.
Yes I did fab those rear quarter panels or I should say , I'm in the process LOL . I have to make a panel from the drivers door to the bumper. I am making the panel in three pieces then I will weld them together into one panel then weld the panel on. It just takes time, practice, and patience and a few good tools
Still work'n... slow but sure. I fabbed up a couple of engine mount perches which might be a little overkill ,LOL
The trans crossmember was fabbed and now on to the firewall.
jpg[/attachment]
jpg[/attachment]
- Attachments
- 20201222_164950.jpg (191.51 KiB) Viewed 114 times
- Site Admin
- Contact:
Keep it up Red, I always enjoy looking at your updates and the work you do I am impressed
Looking forward to more.
I wish I had some good tools, oh well
thank you Mike much appreciated. I just wish I had more time to work on it but I guess that's what retirement is for! LOL having just a few good tools does help oh, I figured if a good fabricator needs good tools, a crappy beginner like me sure as hell needs a good tools!
Also had to replace one of the rusted inner wall panels.
- Attachments
- 20210120_042420.jpg (140.41 KiB) Viewed 84 times
- 20210127_035303.jpg (235.15 KiB) Viewed 84 times
Thanks for the update!
I very much enjoy seeing the fabbing ,, great build!
