Limited slip diff
kcomet67
Limited slip diff
Post by kcomet67 »
Hey guys does anyone know what limited slip rear ends will work on these cars? Specifically my 67.
1967 Comet 202. 289. Work in Progress
Re: Limited slip diff
Good used 8" Trac-Lock units are unobtanium and probably shot if you did find one. Have a 'L' stamped with the ring gear ratio on the carrier tag.
Yukon & Detroit both sell new units that will set you back around $500.
This is what I purchased for our 66 8”
https://www.amazon.com/Ford-Trac-Lock-P ... C67&sr=8-7
vicegrip
Post by vicegrip »
might know of an 8 inch Trac Loc with new clutches.If interested,let me know and I'll find out if the guy still has it.
Post by comethead »
I have a reproduction 8” Ford Traction Loc in the Comet and an Eaton TrueTrac diff in the Falcon https://www.summitracing.com/parts/dtl- ... gI9lfD_BwE :
But MAN :shock: have prices gone up!!
I hear the true trac is the way to go, don’t have to worry about the clutches wearing out. I wasn’t concerned about that when I got the tracloc, it’s just a cruiser, don’t plan on thrashing it toooo bad.
It's surprising where you might find what your looking for when it comes to rear gears.....my comet has a 8in LS unit from a 1976 V8 mustang 2,,,,I have had it in a 64 4spd stang,a,V8 63 falcon now in a 4sp 64 comet,,,,,,,so don't walk past anything,,always take the time to check out everything,,you never know where you might find just what your looking for,,,,,POP
Rocket989
Post by Rocket989 »
Not discriminating between 8" & 9 ":
59.25 1967-1970 Mustang
59.25 1967-1970 Mustang, Fairlane, Comet, Cougar
59.25 1967-1971 Comet, Cougar, Mustang, Fairlane
59.25, 61.25 1967-1973 Torino, Ranchero, Fairlane
59.25, 61.25 1967-1973 Mustang, Torino, Ranchero, Fairlane
1-2 inches is easy to accommodate with all the wheel offsets these days (or if you're not looking for widest tire - doesn't so much matter).
Hey, Rocket! Where you been, man?? :D
