62 Comet Subframe Connectors
62Cometman
Post by 62Cometman »
Other thans Crites I haven't been able to find anyone that has a set of subframe connectors that would fit a 62 Comet. I see the tubular set from Global West Suspension for a Falcon, is there any reason those wouldn't work on a Comet? The front connection is boxed in and the rear is a L bracket
https://www.globalwest.net/916.html
Kingsly
Re: 62 Comet Subframe Connectors
Post by Kingsly »
Hi, Tinman fabrications makes some nice ones for around 180 bucks for a pair for 60 to 63 comet ,summit racing carries them
power band
Post by power band »
The 60-63 front and rear suspension subframes are offset by @ 3". 1 X 3" box tubing and a few lengths of angle steel can be used for a fairly simple fabrication of connectors. Be sure the cross body pan braces are tied in to them for maximum rigidity. I also tied in the rear spring front eye brackets and fortified the rear engine crossmember .
"felt the difference first time I dumped the clutch..."
Image . . Image. Image .Image
Image .Image
have fun
Imo power band has it right.
Other members as well have said they need to be welded in and pick up the floor as well.
If a unibody is flexing everything is moving so everything needs to be tied down.
Some tubing, a mig and some time makes a solid car.
I seen a poster somewhere that kinda says it.
KEEP AMERICA STRONG - WELD IT!
Although Im not American I do agree.
Tue Apr 05, 2022 9:59 pm
Yea you are! a North American! Partners ay? :)
