Hello from Illinois
bluestang67
Re: Hello from Illinois
Post by bluestang67 »
Joe I have spoke to the owner from early 70s till 83 , owner i got it from purchased it in 92 . It still retains the buck tag on the passenger apron .
I posted more pics in showing off thread
Starting from ground zero
I bought mine around '87-'88, sold it in the early '90s. PO was from the Baytown, Tx. area.
Guy I sold it to turned it quick to a guy in Central La. He totally restored it around mid-'90s, best I can remember.
Originally a 3 speed A code car, '71 302 w/ the original 289 intake. He installed a Toploader.
bluestang67
Tue Oct 18, 2022 5:56 pm
This one lived in Indiana all its life , where i bought it south of Indianapolis , PO that seen pics lived out side indy too . This is factory 4 spd
Cool. Just don't see that color often, had to ask.
bluestang67
It has a 78 302 , .040 bore with 65 heads and had a crane Fireball , lost a lobe and put a comp pro magnum in it , the metal from lobe loss got to bearings and started losing oil pressure . Its in garage waiting on new engine .
Had to check the color chart. Looks like yours' is Silver Turquoise. Mine was Ocean Turquoise, just a shade darker.
Still pretty unique to see either these days.
bluestang67
Tue Oct 18, 2022 6:31 pm
Joe yeah code D Silver Turquoise it had one repaint original color .
She looks strong, Bobby. You were blowin' the cobs off those stalks! :lol: 8)
bluestang67
Tue Oct 18, 2022 9:43 pm
She was , but she will be stronger in a bit .
fryedaddy
Post by fryedaddy »
i have a 2 piece header on the drivers side of my 66 with a bb. the z-bar is not in the way at all with hooker long tubes and a 428
fryedaddy
bluestang67
I sit so low long tubes may not clear speed bumps ,
bluestang67 wrote:
Wed Oct 19, 2022 8:18 pm
It may not be too low to hit. My collector flange’s are just under 4” from the pavement, I have never hit them. I also am able to clear the cross rail on my lift using short ramps, no issues. Large Roadkill may be a problem!
bluestang67
Yeah that looks great , can't see them under the car either . May be another Avenue i need to really look down . I dont have a lift , that pic is PO .
Nice stance ! I have doug tri y's they're as long as long tube headers I think. I have an under engine bar with a jack pad. I've rubbed it on one dip near the end of a long straight bottom where I like to stomp bout 3 gears off . that video reminds me of the place! :D probably running 90 mph or more ,but other than that one place a couple times I haven't rubbed any. & I may be a tad lower than you.bar is actually too low I need to raise it a little . I doubt it would rub my headers even if that bar wasn't on there. I was worried more about the oilpan,that could be a nightmare. so it's a jack pad ,protector bar & brace .
bluestang67
Johno stance is air shocks , hopefully new tire combo will look the same when its done . I'm going to be looking at all that fit with the z bar .
There was a little concave in my pan and it just kissed the pick up , I took it off and removed it when i did the new cam.
