New build 62 Comet
New build 62 Comet
Hello from Phoenix
I acquired my first ever project car, a 1962 comet. Gentleman that had it was nice enough to tear it apart and lose the stuff. I did get a 66 Ford 200 and two speed transmission with it. Was given some seats from my son, 14-inch tires and rims from a user in the group, and tire help from my grandson who works for a tire shop. Friend at church "gave" me a 302 for it, but that is a later upgrade to the car.
Still looking for a better transmission for it.
Here are a couple of beginning pictures.
My girl Abbey is helping with the truck
- Attachments
- Motor.jpg (84.49 KiB) Viewed 517 times
- inside.jpg (102.71 KiB) Viewed 517 times
- inside 2.jpg (107.69 KiB) Viewed 517 times
- Car.jpg (114.14 KiB) Viewed 517 times
- Boss/Cyclone
- Site Admin
Re: New build 62 Comet
Glad you started a build thread. We have some build threads that extend over 10 years. It is great to look back and see your progress. Good luck.
Great to see another early Comet Six car getting put back together for driving into the future. The 2 speed 'slushomatic' is what gave the six cars their questionable reputation. '66 200 can accept many later improved trannys. The iconic 3 speed C4 is a reasonable option but if you want to go 3 pedals, the options exist to simply convert to virtually unbreakable 3 spd Toploader, 4 speed TL or a Fox body 'Stang Overdrive T5 for real sport performance.
later Mustang, Falcon, Maverick, Fairmont,Granada and Comet six cars can provide the needed tranny parts, proven and/or creative mods' of the small block six can provide the fun.
My '61 is a work in progress but after @ 20 years, I'm at least half done !.
have fun
'61 T'Bolt Six: Ford 250 Small Block Six Bored for TRW 258CID Pistons, Clifford Shot Peened Rods, Clifford 272H Cam, Cloyes timing set, Melling blueprinted HP oil pump, Offenhauser Tri-Power 3X1 aluminum intake manifold w/ Offy progressive linkage, Modified Holley 1904 series glass bowl carbs, GM HEI ignition trigger, Champion Racing spark plugs., Matte black/alum. 6=8 Clifford VC. SFI 157 neutral balance-light weight flywheel spinning Centerforce Stage II Clutch, T5-Z Cobra 5speed tranny, Short throw Hurst Indy shifter, 8” 3.80:1 TracLoc Posi rear, Shelby sway bar, "Caltrac" type traction devices Mustang front strut bars, Scarebird Disc front brakes, Fabricated subframe connectors and crossmembers, 8 Point Roll bar, 5 point Safety Belts, Mustang 5.0 alum. racing radiator, Perma-Cool electric pusher fan, Holley fuel pump/pressure regulator, Hooker 6602 dual out longtube headers, Smithy silencers, Original tube radio, vacuum wipers and front fender Gunsights……
have fun
I am JAZZED!
Got 14-inch tires that fix the car.
Picked up a 1967 Ford 200 that was bored out and has a cam. It comes with the C4 transmission.
I will have to post selling the other tires, engine and transmission.
Buying the start of a lot of parts.
Going to rebuild the front end before putting in the engine.
Hope it is as fun as it looks
'62 should have 62-65 6 cyl front suspension.
there is some value in upgrading to '65 V8 front suspension components - Center link / tie rod ends are considerably heftier if needed for use.
Might want to consider converting to 65 suspension to reduce bump steer.
https://www.cometcentral.com/forum/view ... bump+steer
I was going to ask if you were upgrading to 65 parts like mentioned above, I dont think all of 62 stuff is available, so if you need most all of it the 65 stuff would be cheaper but you would need to anti up for a set a spindles & probably would want an 8'' rear so you have 5 lug front & back. then you need new wheels. But you would have a better driving car & will always be able to find parts -all but the center link is same as 65-66 mustang. & the center link is same as the more plentiful falcon so they should always be around.
... " you would need to anti up for a set a spindles & probably would want an 8'' rear so you have 5 lug front & back. then you need new wheels."
BTW - early Falcon/Com/Stang 5 lug steering stuff including spindles getting very hard to find in usable shape. 70's Maverick/Comet may be reasonable option and the availability of heavier duty 4 Lug spindles is possible.
'61 Comet with '71 Maverick 4 lug spindles with disc conversion using 14" 4lug wheels and Maverick 4 lug 8" rear with 3.80 'posi'.
Thank you all for your replies.
I am now looking to upgrade instead of replacing the parts for the one I have.
I really like the information that I am getting in this forum.
I am going to sell the engine, trans and old bucket seats and that should help to offset the cost.
Had to put the car on hold until I finished this semester worth of schoolwork. 60 years old and I’m back in college.
What I’m looking for is the hardware kit for the drum breaks. Everywhere I go does not have it and the one place I did find it back ordered it for five weeks. Does anyone know what drum kit would fit a 62 Comet?
