on my 65 ,I am working on a support frame inside my trunk for mounting panels ,and wanted to ensure I leave clearance for the trunk lid spring ,unfortunately I lost a batch of my disassembly pics including the one of the trunk spring arrangement.
I think I am good .Does anyone have a good pic of where the springs sit both for clearance and the eventual re assembly?
Tunk lid spring
Re: Tunk lid spring
Re: Tunk lid spring
Thanks Lou and Jim ,kind of hard to tell.in my pics My verticals come up right at the crest of where the trunk pan rises and and flattens out. .then there will be 1/2 of material bolted to that in the trunk if that help...dang computer crash
Re: Tunk lid spring
Re: Tunk lid spring
Are you talking about the 4 verticals you have coming up from trunk floor to the underneath of the rear package tray?Kingspeedy2 wrote:Thanks Lou and Jim ,kind of hard to tell.in my pics My verticals come up right at the crest of where the trunk pan rises and and flattens out. .then there will be 1/2 of material bolted to that in the trunk if that help...dang computer crash
If so I took a square today put it upright with one side flat with floor and brought the vertical edge of square back too where the trunk rises and flattens out. The vertical edge of square ended up a little over two inches (about 2.25") in front of the torsion springs (rods). So if your putting a panel there 1/2" thick you should still have 1.5" clearance to the springs, probably a little more.
Re: Tunk lid spring
Yes that's exactly right Lou those verticals,thanks for all the effort and picture
Re: Tunk lid spring
If ya wanna make a tool.
