63 Convertible seats HELP!!!
I am not really having a hard time sourcing most of my needed parts.
I am however stuck with the seats.
1963 Comet Convertible s22
The rear seat is just rusty springs that break when you touch the seat
The fronts are pretty much the same. Just slightly better.
Has anyone had this issue?
Where do I get seats? The upholstery seems easy to locate. Just not the bases and springs.
Are there any other cars that will work? Besides possibly a falcon?
Thanks all
Thanks all
Re: 63 Convertible seats HELP!!!
Falcon seat are the same...
Early Mustang buckets should also be very close
bolt spacing is a little different, you'd need to drill new holes,probably 3 on each seat.or make adapters. but they would fit just fine in the car. but comet upholstery may not fit.bmmaurer wrote:Early Mustang buckets should also be very close
So ideally, I can buy the replacement Falcon foam for my Comet? Or possibly Mustang seat foam?rhead63s22 wrote:Falcon seat are the same...
I used falcon foam with slight modifications.
Comet Bruce
Comet Bruce
Those may be for a hardtop which are different than convertible seats. tracks are different & they sit higher (hardtop seats).
What kind of modifications?bmmaurer wrote:I used falcon foam with slight modifications.
Comet Bruce
And the Stang seats have a much lower profile.
The foam in this area needed to be cut to be narrower across the top edge to accommodate a different thickness of the area.
Bruce
Bruce
Gorgeous car! Can I ask what pieces of your interior needed replaced and how hard they were to obtain or where you got them?bmmaurer wrote:The foam in this area needed to be cut to be narrower across the top edge to accommodate a different thickness of the area.
Bruce
Dash Pad replacement from Just Dashes... http://www.justdashes.com/
NOS seat covers and Repo Door Panels, seat foam from Jake at https://www.falconcometinteriors.com/
Carpet form ACC
Comet Bruce
Carpet form ACC
Comet Bruce
