260 head gaskets
efmiller
260 head gaskets
Post by efmiller »
rebuilding a 260, all if the kits come with 289/302 4 inch bore head gaskets. i have built a few 302s. my question is, how much compression will i lose using these oversized bore gaskets. it is a daily driver, so not looking for a hotrod.. or is it worth finding actual 260 head gaskets
Re: 260 head gaskets
Here's a good calculator to account for gasket hole & piston bore- https://www.gofastmath.com/compression- ... calculator
I don't think you will find 260 bore sized head gaskets. 4.030 is the smallest commonly sold bore sized head gaskets that I have seen. I am sure it will be fine with those. I used them on a 260 I ran years ago with no issues.
bmmaurer
Post by bmmaurer »
All of those are over 4" bore, not specifically for a 260
Ran the calculations between 4.10 gasket bore & 3.90 just for the heck of it.
Less than 0.1:1 difference. The combustion chamber tolerances varied more than that from the factory.
I don't see any available but I wonder if the steel shim gaskets are still available to raise compression? That was the ticket many years ago.
bmmaurer
Post by bmmaurer »
efmiller wrote:
Sun Sep 25, 2022 10:34 am
You will see NO performance issues. Have used these twice. no issues
efmiller
Post by efmiller »
thanks guys. i will go with the standard kit. it will be going into my daughters 63 4 door.
Did you find a piston besides the Silv-O-Lite for the rebuild?
